Managing cisco switches using telnet
Oct 27th, 2008
I have about six cisco edge (Access layer)switches, all are uplinked to a cisco backbone (Core layer) switch by using the normal hierarchy design that all we know already and get used to it. Each edge switch got certain layer 2 vlans configured. And as we know, all the vlans ip addressing and intervlan routing decisions exists in the backbone switch. All i want is to telnet to all the edge switches from single location without opening several telnet sessions. For example, if my host sit in swA and i want to telnet to swC, i don't need to open a telnet from swA to swB then swC. The trick here is that telnetting to the interface vlans on the backbone will open the session to that backbone not to the associated edge switches.
I solved this by creating a management vlan in each switch with ip address (SVI).It works but still forcing me to open various telnet sessions.
BTW, all trunks are dot 1Q.
Is there anyway to make me telnet to these switches centrally and without several sessions?
Thanks.
Ahmad
Overall Rating: 4 (1 ratings)
glen.grant Mon, 10/27/2008 - 14:57
If all your access switches have a management ip address assigned then you should be able to telnet directly to the device unless its being blocked by vty access list . Each switch should have a management ip address and a default gateway assigned to it .
AhmadMounir30 Mon, 10/27/2008 - 15:12
Hello glen,
Many thanks to your fast reply. Big appreciation! ... But, i don't want to connect directly, i want to connect from a host in specific vlan. For example, My host sit in vlan50 in switchA with ip address 192.168.1.2 and my gateway is 192.168.1.1 (interface vlan). Now, i want to telnet to switchB which is in another building. And we know that trunks are layer 2 links are not identified by ip addresses. In this case, how the telnet works?
Thanks..
Ahmad
Jon Marshall Mon, 10/27/2008 - 15:16
Ahmad
Even though your switches are L2 you can have one L3 vlan interface on each switch. So what you need to do is use a vlan for managing your switches.
Lets say switch C is your core switch and the vlan for managing switches is vlan 10
On core switch
int vlan 10
ip address 192.168.10.1 255.255.255.240
on each edge switch
int vlan 10
ip address 192.168.10.x 255.255.255.240
where x = an unused IP address.
Then on each edge switch add this to your config
ip default-gateway 192.168.10.1
Edit - you need to make sure vlan 10 exists on all switches ie. if you do a "sh vlan" on each switch you should see vlan 10.
Jon
Mo'ath Al Rawashdeh Mon, 10/27/2008 - 15:17
hi Ahmad,
Routing between VLANs needs to be configured on your core switch between the user VLANs, and the management VLAN.
So i suggest that you make sure to configure interface vlan IP address for the management VLAN on the core switch, and configure this IP address as the default gateway on all edge switches.
It should work.
Cheers,
AhmadMounir30 Mon, 10/27/2008 - 15:25
Hello all,
Many thanks for all these fast replies. Yes wow, i think this is the solution. I will try it tomorrow inshallah.
Thank you guys so much.
CHEERS
AhmadMounir30 Thu, 10/30/2008 - 00:49
Hello muarawashdeh,
I tried the config. that you've told me but unfortunately it didn't work. Okay, let me clear things up ... i just need to telnet to all edge switches from a single PC in a specific vlan. When i configured the switches as you said, i can still only telnet to the core switch not other switches ... In other words, i can ping the management vlan 10.10.8.1 in the core switch but i can't ping the same management vlan 10.10.8.2 in one of the edge switches. Vlan50 is the management vlan number .. let me paste my config. in another thread.
Ahmad Mounir
Mo'ath Al Rawashdeh Mon, 10/27/2008 - 15:11
Dear Ahmad,
Can you attach the configuration of any of the edge switches? as i need to see whats preventing you from this.
Cheers mate,
Muath
glen.grant Thu, 10/30/2008 - 05:55
Can you specify what ports these 2 devices are hung off of ? Nothing marked in config and you have a lot of stuff that doesn't need to be in the access switch with SVI's etc... I would verify that all your layer 2 vlans are created and the the trunks are working and passing the vlans you think they are.
pkaretnikov Thu, 10/30/2008 - 19:54
Your edge switches don't know how to get around using layer 3 with the way they are set up right now.
On your edge switches:
(2 commands)
no ip routing
ip default-gateway 10.10.8.1
*or*
(1 command)
ip route 0.0.0.0 0.0.0.0 10.10.8.1
Also, to make your configs save a bit more neatly use the 'term len 0' command so the screen doesn't pause.
Hope that helps.
AhmadMounir30 Sun, 11/02/2008 - 00:44
Okay .. now i can ping from my host to 10.10.8.1 and 10.10.8.2 but i can't telnet to them. Only ping.
Any suggestions?
Ahmad Mounir
