ACL/interface
Marwan ALshawi Mon, 10/27/2008 - 20:18
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
although i see your question not spicific !!!
but lets say u can leave an ASA firewall without ACL
if u have the folloiwng simple network
egde firewall
two interfaces inside and outside
users connected to inside with higher securty level
other networks like internet connected to outside with lower security level
only u need internal users to access the internet or the inetwork behind the outside interface
u may need to configure proper NATing only
this case u dont need ACL
good luck
if helpful Rate
Marwan ALshawi Mon, 10/27/2008 - 22:17
Aksher
your question is confusing
in general ACL existed to make what is called paket filltering mostly on L3/L4
u can use router or firewall without ACL
but the thing is depends what you wnat to achieve, where the device is located in ur network and so on
hope this helpful
