Cisco ASA 5505
manamsamuel
I just received a cisco ASA 5505 from cisco yesterday for my site to site VPN connection. I connected my yellow straight through cable to the e0/1 port as directed by the install manual and set my Pc to DHCP but the ASA 5505 is not giving out IP to my PC. I also tried a static IP of 192.168.1.2 on the same subnet with the management IP on the box but no joy..I really need help as my remote site is down. Please let me know if there is any config i need to put on the ASA box before i can run the ASDM manager.
Thanks.
j.bourque
I'm not positive these come with DHCP enabled by default. I suggest using a console cable to the ASA and confirming the following.
interface Vlan1
nameif inside
security-level 100
ip address x.x.x.x 255.255.255.0 ie 192.168.1.254, setup your LAN connection with 192.168.1.1/24 and a DG of the ASA's ip you assigned. You'll want to confirm that the ASDM image is loaded in flash and then put the folling command in, asdm location disk0:[nameofasdmimage] along with the command #(config)asdm location 192.168.1.0 2555.255.255.0 inside
I finally figured it out..Someone played around with the factory default config. I think it does come with DHCP enable. All i did was to issue a 'config factory-default' and a write mem.
This is the factory default config:
ASA Version 8.0(3)
hostname ciscoasa
enable password xxxxxxxxxxxxxxxxx encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxxxxxxx.xxxxxxxx encrypted
ftp mode passive
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
I can now connect via the web interface using https://192.168.1.1/admin
The problem now is when i click on Run ASDM, i have the following error;
ASDM is unable to continue loading, click ok to exit from ASDM.'unconnected sockets not implemented.
Please help!!!!!!!!!!!
sounds like a bad/corrupt asdm image. if you have the cd I would tftp a new image to the ASA flash or download the image from cisco's website and tftp that up.
I think am learning the hard way this time around. I upgraded my jvm (Java virtual Machine) and it works.
Thanks for you time.
