RIPv2 Authentication
Oct 28th, 2008
Does any one knows what exactly is used as input for the md5 algorithm when using routing updates authentication? I tried to calculate a md5 sum for the routing table concatenated with the key-string, but i haven't obtained the same value as in the authentication trailer. Is there any other data used as input for the md5 algorithm or some padding between the key-string and the routing table?
