Hide the called number beetwen internal extension without 067
Oct 28th, 2008
I want hide my number when i make internal calls without 067, i want make this service transparent for the end user..For external call i can hide the number without put 067 but is impossible for internal..
Carlos
Overall Rating: 1 (1 ratings)
pklos Tue, 10/28/2008 - 06:20
you can do it using translation pattern and special CSS for hidden phones.
regards,
PK
ip.operations Tue, 10/28/2008 - 08:13
But why kind of special CSS do you mean?
I configure a tp_ 067.XXXX ---Called transformation mask XXXX. And is work fine but i need pulse 067 send automatically not manually. I mean transparent for the user.
THanks
pklos Tue, 10/28/2008 - 08:17
you do CSS with additional partition (first), then you do translation pattern with 067xxx in this partition which does number hiding and sends call to 067xxxx in ordinary partition.
regards,
PK
pklos Tue, 10/28/2008 - 09:04
you can do hiding translation for all number. no problem.
davidjani Tue, 11/04/2008 - 05:46
I think you mean you want this to happen without the user having to dial 067 as a prefix.
If this is the case, try the above i.e. using a seperate partition and a new CSS containing this partition first and then create a translation pattern containing DN ! within new partition and send out of normal CSS with mask XXXX. The '!' means "match anything".
Jani.
