No Ringback PBX Alcatel
cristian.munoz
Level 4
Level 4
Hi, i have a problem with the ring back. When call from IP Phone to PBX by Gateway H323 with E1, using the dial-peer voice 600 pots, it works. But if i dial using dial-peer voice 750 pots i not have ringback tone. The difference is the 600 is the main pbx and the 750 is another pbx. I'm using a couple E1 to connect at the main pbx only.Pls see the dial peers.
tone ringback alert-no-PI
preference 1
destination-pattern 6...
progress_ind setup enable 3
fax rate disable
direct-inward-dial
port 0/1/1:15
prefix 6
preference 1
destination-pattern 7...
direct-inward-dial
port 0/1/1:15
prefix 7
Any idea?
6 Replies 6
cristian.munoz
Level 4
Level 4
Here a debug isdn q931 :
Oct 28 13:40:03.526: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 6300
*Oct 28 13:40:03.526: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x764C
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18392
Preferred, Channel 18
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = 'IP Communicator'
Calling Party Number i = 0x0081, '25826000'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '6300'
*Oct 28 13:40:03.554: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xF64C
Channel ID i = 0xA98392
Exclusive, Channel 18
*Oct 28 13:40:03.610: ISDN Se0/1/1:15 Q931: RX <- PROGRESS pd = 8 callref = 0xF64C
Progress Ind i = 0x8581 - Call not end-to-end ISDN, may have in-band info
*Oct 28 13:40:03.618: ISDN Se0/1/1:15 Q931: RX <- ALERTING pd = 8 callref = 0xF64C
Progress Ind i = 0x8582 - Destination address is non-ISDN
R3825#
have you find a solution for this,,,
im facing similar to your problem !!!
please advice if you...
regardsm
Hi Hassan
In the global config:
voice call send-alert
In the dia-peer pots:
progress_ind alert enable 8
In the dial-peer CUCM
Cristian
edison_abad
please try to add this command inside your Dial-peer 750:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml
subash cobi
Anyone found a solution for this.
I'm a same issue with alcatel PABX.
But i only don't hear ring-back if i call the alcatel analog phone, if call a alcatel digital phone i do hear ring back.
This is the debug for calling a digital phone (extn 0790)
Dec  3 16:54:01.404 KUL: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 681
Dec  3 16:54:01.404 KUL: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0C46 callID = 0x950B switch = primary-net5 interface = Network
Dec  3 16:54:01.404 KUL: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0C46
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98381
        Calling Party Number i = 0x0081, '681'
        Called Party Number i = 0xA1, '0790'
                Plan:ISDN, Type:National
Dec  3 16:54:01.432 KUL: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8C46
Dec  3 16:54:01.456 KUL: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8C46
This is the debug for calling an analog phone (extn 0649)
Dec  3 16:54:39.344 KUL: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 681
Dec  3 16:54:39.348 KUL: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x0C47 callID = 0x950C switch = primary-net5 interface = Network
Dec  3 16:54:39.348 KUL: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0C47
        Sending Complete
                Standard = CCITT
        Called Party Number i = 0xA1, '0649'
Dec  3 16:54:39.372 KUL: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8C47
Dec  3 16:54:39.400 KUL: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8C47
This is the dial peer to the Alcatel PABX.
dial-peer voice 678 pots
destination-pattern 0[678]..
progress_ind progress enable 2
progress_ind connect enable 2
port 0/0/0:15
forward-digits all
I notice that when calling a digital phone, alcatel does not provide a PI, so cisco router is able to generate the ring back since the PI is absent. But when calling an analog phone there is a PI sent over.
If your PBX are Actel's, please refer to this:
OMC>>External Lines>>Protocols>>ISDN Trunks>>Parameters>>check"send ringback tone for incoming calls"
