IOS Server Loadblancing on Cisco 1811
Oct 28th, 2008
Is it possible to use the IOS Server Load Balancing Feature Set on a Cisco 1811. Does this feature set allow for both full routing features and Server Load balacing features? I would like to use this device as both a firewalling router running OSPF in two areas, NAT/PAT and for Server Load balancing.
Overall Rating: 4 (1 ratings)
Jon Marshall Tue, 10/28/2008 - 07:11
Feature Navigator is your friend when it comes to this sort of thing
I had a quick check, altho you may well want to do a more thorough one, and IOS SLB does not appear to be supported on the 1811 router.
