No ringback tone when RX <- PROGRESS
Oct 28th, 2008
Hi, I have a scenario :
ip pnone---ccm---gw---pbx1---pbx2
Using a IP Phone, when i call to pbx1 it works. But if i call to pbx 2 i not ear ringback tone. In the debug isdn q931 only i see a difference in the RX <- PROGRESS. When i receive this param not ear ringback tone.
emorgan Tue, 07/07/2009 - 19:01
Having the same problem. Did you ever find a solution.
Eric
Adrian Saavedra Tue, 07/07/2009 - 22:37
  • Gold, 750 points or more
Hi Eric,
Did you try configuring progress_ind alert enable 8 command under the POTS dial peer that matches outbound calls?
Best regards,
- Adrián.
