VPN 3000 Concentrator
Answered Question
Oct 28th, 2008
Does anyone know where I can find the meaning of this message?
465 10/28/2008 14:48:06.640 SEV=4 IKEDBG/97 RPT=410 208.96.196.242
Group [208.96.196.242]
QM FSM error (P2 struct &0x6810ef4, mess id 0xeb16b91f)!
466 10/28/2008 14:48:06.640 SEV=7 IKEDBG/65 RPT=39116 208.96.196.242
IKE QM Initiator FSM error history (struct &0x6810ef4)
<state>, <event>:
QM_DONE, EV_ERROR
QM_WAIT_MSG2, EV_TIMEOUT
QM_WAIT_MSG2, NullEvent
QM_SND_MSG1, EV_SND_MSG
Correct Answer by ajagadee about 8 years 8 months ago
QM FSM Error
The IPsec L2L VPN tunnel does not come up on the PIX firewall or ASA, and the QM FSM error message appears.
One possible reason is the proxy identities, such as interesting traffic, Access Control List (ACL) or crypto ACL, do not match on both the ends. Check the configuration on both the devices, and make sure that the crypto ACLs match.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00800949c5.shtml#qms
Arul
*Pls rate if it helps*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Tue, 10/28/2008 - 08:35
  • Cisco Employee,
QM FSM Error
Arul
wgranada1 Wed, 10/29/2008 - 06:54
Yes this makes it clearer, just a fyi found out the the distant end didn't have a route back. Thanks for your help!!!!
