BGP Prepend
Answered Question
Oct 28th, 2008
Just a quick question, if i have a community string from an ISP that will prepend my route, if i set that community 3 times will it prepend it 3 times?
for example
xx:2200 prepend to peers (ISP XX )
if i set community on 1.1.1.0/24 xx:2200, xx:2200, xx:2200 would most ISPs prepend it 3 times?
Thank you,
Correct Answer by Harold Ritter about 8 years 3 months ago
Tomasz,
You can't set the same community more than once for given prefix. On the other hand, the ISP usually provides different communities to prepend the aspath a different number of time.
For instance:
xxx:2201 = prepend once, xxx:2202 = prepend twice and so on.
Overall Rating: 5 (1 ratings)
Correct Answer
Harold Ritter Tue, 10/28/2008 - 09:25
Tomasz,
For instance:
