Event: NULL TCP PACKET
Oct 28th, 2008
Hello all,
we are incrementally receiving a lot of MARS events that comes from Cisco IDS, all those events are “ NULL TCP PACKET”, and the destination is always the same, a smtp ironport machine trough the 25 port, from diferent public IPs.
Does anybody have a similar scenario? What can we do?
Farrukh Haroon Wed, 10/29/2008 - 04:54
  • Red, 2250 points or more
What is the frequency of such packets? A few of them are usually negliglble, this is specially true if you are at over/near utilization for your internet link.
Farrukh
izaskun.onandia Wed, 10/29/2008 - 05:42
Thank you for the reply,
the frecuence is
augus 925
September 1828
October till thursday 23 2329
And growing up. I think it is not licit trafic
Izaskun
Farrukh Haroon Wed, 10/29/2008 - 07:16
How is the congestion/utlization on your Internet Link?
Exactly 'which' IPS signature is firing btw? (you can check this out by the raw event logs in MARS, this is done by clicking the icon next to the name of the reporting device).
Farrukh
izaskun.onandia Wed, 10/29/2008 - 08:36
The ratio of average use is 88%, and the maximun peak is 5%.
Our IPS signature is 364
Thanks again
Izaskun
rajett Wed, 10/29/2008 - 15:39
  • Cisco Employee,
What make/model of IPS are you running?
Have you checked with that vendor for known false positives?
If there are false positives that will help you with tuning your sensor or with tuning out the alert on MARS.
Raymond
izaskun.onandia Thu, 10/30/2008 - 01:05
We've a CISCO IPS, I think that this traffic is not a false positive, I think it is ilegal trafic.
rajett Thu, 10/30/2008 - 11:36
  • Cisco Employee,
What IPS signature are you seeing firing? I don't recognize 364.
Have you done a packet capture on the traffic? If so, what are you seeing out of the ordinary?
Are the sources of this connection a valid host or is it from areas of the world that are more known for hacking?
izaskun.onandia Fri, 10/31/2008 - 01:16
The signature version 364 and the IPS version is 6.1 (1) E2.
It is suppoused that is a single TCP packet with none of the SYN, ACK,FIN or RST flags.
It comes from different public IP's that comes from different ISP's.
Izaskun
