metalium2007 Tue, 10/28/2008 - 08:41
  • Bronze, 100 points or more
Jays,
Upgrade Paths to Cisco Unified Communications Manager 7.0(1)
These sections contain information about upgrading to Cisco Unified Communications Manager 7.0(1).
Direct Upgrade
You can upgrade directly to Cisco Unified Communications Manager 7.0(1) from
•5.1(3)
•6.0(1)
•6.1(1)
•6.1(2)
Upgrade by Using Data Migration Assistant
You can upgrade to Cisco Unified Communications Manager 7.0(1) via Data Migration Assistant (DMA) from:
•4.1(3)
•4.2(3)
•4.3(1)
•4.3(2)
From this good doc:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_0_1/cucm-rel_notes-701.html#wp579989
Hope this helps,
Met.
Rob Huffman Tue, 10/28/2008 - 08:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jason,
Here is a little more to add to the good tips from Met (+5 points Met :)
Upgrading to Cisco Unified Communications Manager Release 7.0(1) from Cisco Unified Communications Manager 4.x Releases
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/7_0_1/upgrd701.html
Data Migration Assistant User Guide Release 7.0(1a)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/7_0_1/dmaug701a.html
Hope this helps!
Rob
