ACE4700 conn limit and rserver down
Answered Question
Oct 28th, 2008
I have this configuration:
serverfarm host SF_BOOKING
failaction purge
predictor leastconns slowstart 60
probe PROBE_HTTP_BOOKING
retcode 200 500 check count
rserver SERVER-1 80
conn-limit max 1200 min 1100
inservice
rserver SERVER-2 80
inservice
rserver SERVER-3 80
inservice
and state of servers is:
SKY-ACE1/www# sh serverfarm SF_BOOKING detail
serverfarm : SF_BOOKING, type: HOST
total rservers : 3
active rservers: 2
description : -
state : ACTIVE
predictor : LEASTCONNS
slowstart : 60 secs
failaction : PURGE
back-inservice : 0
partial-threshold : 0
num times failover : 0
num times back inservice : 0
total conn-dropcount : 0
Probe(s) :
PROBE_HTTP_BOOKING, type = HTTP
----------connections-----------
real weight state current total failures
rserver: SERVER-1
10.218.71.30:80 8 MAXCONNS 636 7530 140
max-conns : 1200 , out-of-rotation count : 0
min-conns : 1100
conn-rate-limit : - , out-of-rotation count : -
bandwidth-rate-limit : - , out-of-rotation count : -
retcode out-of-rotation count : 0
load value : 0
rserver: SERVER-2
10.218.71.35:80 8 OPERATIONAL 562 7297 127
min-conns : 1100
load value : 0
rserver: SERVER-3
10.218.71.40:80 8 OPERATIONAL 529 4712 58
max-conns : - , out-of-rotation count : -
min-conns : -
load value : 0
I have two questions:
1. Why is state of SERVER-1 'MAXCONNS', when real conns is under 1100 (min-conns)?
2. I find that SERVER-1 goes down (reason probe), client got TCP RST. Client is requesting VIP of course. When I clear 'conn-limit' to default (none), this problem isn't. The same if SERVER-3 is in this state (MAXCONNS). MAXCONNS is cancelled after 'no inservice, inservice'.
It's feature or bug? :)
sw release: 3.0(0)A1(8.0)
(I found no bug for this release)
thanks for any help,
martin
Correct Answer by Gilles Dufour about 8 years 5 months ago
CSCsr20530: rservers are stuck in MaxConn state
CSCsr65774: server stuck in MAXCONN if conn-limit and RL hit simultaneously
CSCsq83367: server stuck in MAXCONN state if inservice/noinservice
CSCsr63601: rserver are stuck in MaxConn state after ft switchover
CSCsv21495: rservers stuck in Max-conn while configuring limits during traffic .
CSCsr72390: rserver do not get conn after going OOR w/ maxconn
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 11/04/2008 - 06:30
  • Cisco Employee,
Martin,
the maxconn limit function is broken in your release.
You should try A3(1) and see if it helps as many fixes where added already...but unfortunately there are still a few being worked on.
Gilles.
Martin Kyrc Wed, 11/05/2008 - 01:07
Gilles,
thank you for this information. It's very helpful for me, because I can't find it in release notes, or bug tool.
can you tell me, where can I find this information? (some release note, or bug ID).
thanks.
martin
Correct Answer
Gilles Dufour Wed, 11/05/2008 - 01:43
  • Cisco Employee,
