DMVPN gre question
Answered Question
Oct 28th, 2008
I have a DMVPN setup between 1 hub & 1 spoke router.
Here's Hub tunnel config:
interface Tunnel1
ip address 10.101.0.1 255.255.255.0
no ip redirects
ip mtu 1416
ip nhrp authentication abcd
ip nhrp map multicast dynamic
ip nhrp network-id 123
no ip split-horizon eigrp 100
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 1234567
tunnel protection ipsec profile DMVPN
router eigrp 100
network 10.100.0.0 0.0.0.255
network 192.168.9.0
no auto-summary
Spoke Config:
interface Tunnel1
ip address 10.101.0.250 255.255.255.0
no ip redirects
ip mtu 1416
ip nhrp map 10.101.0.1 publicIPhere
ip nhrp map multicast publicIPhere
ip nhrp nhs 10.101.0.1
ip nhrp cache non-authoritative
tunnel source FastEthernet0/0
tunnel key 1234567
router eigrp 100
network 10.101.0.0 0.0.0.255
network 192.168.2.0
no auto-summary
My problem is that I cannot seem to get the EIGRP working between the HUB and the SPOKE routers. My isakmp and ipsec work fine. I am able to ping both GREtunnel IP's through the IPSEC tunnel.
If I use static routing communication works fine, is there any way to get the eigrp to go through the tunnel so I can avoid static routing?
TIA,
Fred
Overall Rating: 5 (1 ratings)
fredj1234 Tue, 10/28/2008 - 09:30
Thanks! That was the problem and I kept overlooking it.
