Unity Connection Upgrade to 1.2(1)SR2 missing req 1.2(1)SR1
Oct 28th, 2008
I have a Unity Connection server where I am trying to upgrade from 1.2(1) to 1.2(1)SR2. SR2 requires SR1 to be installed first. I looked for SR1 to install first, but this file is not listed in the SW download page. Is this an oversight by Cisco?
Rob Huffman Tue, 10/28/2008 - 10:46
Hi Randall,
From the Unity Connection portion of the software downloads click on 1.2(1) and you will see a number of files available. Down towards the bottom of the page you will see;
CiscoUnityConnection1.2.1SR1.exe
Release Date: 13/Aug/2006
Unity Connection 1.2(1) SR1
Size: 32954.58 KB (33745481 bytes)
Hope this helps!
Rob
