ASA auth-prompt prompt Please login: doesn't display the “user acceptance a
Oct 28th, 2008
The following example shows the output of the show running-config auth-prompt command:
hostname(config)# show running-config auth-prompt
auth-prompt accept You're in!
auth-prompt reject Try again.
hostname(config)#
I have to have a “user acceptance agreement” when logging in to VPN on a Cisco ASA 5520 ver7.2(3) I have configured it properly but when I login I never get the prompt
XXXXXX/pri/act# show running-config auth-prompt
darrenj Tue, 10/28/2008 - 16:02
What are you trying to do here? Is this for when users VPN into the ASA? When people try ssh/telnet to the ASA or what?
auth-prompt is trypically used for cut-through proxy. This is when a user has to authenticate via the ASA before it can access certain devices through it. If its VPN agreement or ssh/telnet to the ASDM you want to look at configuring banners...
Hope that helps
Darren
salmodov Wed, 10/29/2008 - 07:08
We are using the ASA like a VPN Concetrator. I have it set up were users login to it and establish a VPN and authenticate against an RSA token server.
The routing and the tunnels work fine and the users do get authenticated but they never receive a propmt banner or what ever you want to call it like they do when they logon via 3030 or similar.
I even tried as you suggested and used this config they should get a banner after a successful logon but they dont. Any ideals?
banner login =====================================================================
banner login You are attempting to connect to a restricted system. Connections
banner login to and from this system are logged. Please disconnect now if you
banner login are not an authorized user of this system.
darrenj Wed, 10/29/2008 - 11:43
Yes, try applying the 'banner value' command under group policy x attributes (where x is your group policy name!). It works for me :-)
Darren
