1751 IS ABLE TO MAKE CALL OUT,BUT CANNOT RECEIVE ANY
Oct 28th, 2008
Hi Pros,
I been doing some fexes over IP with cisco 1750.I've decided to you use 1751 now, I am able to place call to the PSTN from the 1751; however,calls from the PSTN deos not get to the router.
The route has IOS:12.3(2)T4 with Flash c1700-sv3y-mz.123-2.TB.bin....
there the actual config
hostname xxxx
logging buffered 20000 debugging
logging rate-limit console 10 except errors
enable secret xxx
no ip dhcp-client network-discovery
call rsvp-sync
voice class codec 1
codec preference 1 g729r8
interface FastEthernet0/0
ip address 10.7.7.170 255.255.255.0
no ip redirects
no ip unreachables
no ip route-cache
no ip mroute-cache
speed auto
full-duplex
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 f0/0
ip route 1.1.1.1 255.255.255.255 Null0
no ip http server
no cdp run
voice-port 2/0
echo-cancel coverage 32
timeouts interdigit 3
voice-port 2/1
dial-peer voice 200 voip
huntstop
preference 1
max-conn 1
destination-pattern .T
voice-class codec 1
session target ipv4:10.10.243.1
dtmf-relay cisco-rtp
playout-delay nominal 250
no vad
dial-peer voice 100 pots
destination-pattern 403451xxxx
port 2/0
scheduler allocate 20000 1000
end
AND THERE THE DIAL-PEER on getway to provide dialton
dial-peer voice 4510542 voip
huntstop
destination-pattern 4034510542
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target ipv4:10.7.7.170
playout-delay mode fixed
fax rate 7200
ip qos dscp cs5 media
no vad
Thanks in advance for your helps guys
Ayodeji Okanlawon Wed, 10/29/2008 - 01:30
  • Cisco Designated VIP,
    2017 IP Telephony
what exactly is the problem you are having? What do you mean you caanot receive calls?
What call procesing agent are u using? CCM or CCME?
CrazyDonJuan Wed, 10/29/2008 - 14:33
The problem is the router cannot receive any calls from the voice getway.However, it is able to call out using the same voice getway.
And I am not using CCM nor CCME.
Crazy
