Unity 5.0(1) - Settings in Subscriber/greetings/after greeting don't work
Answered Question
Oct 28th, 2008
I'm using unity to build a small menu tree, and it works fine, except on a few subscribers I have changed the "after greeting" option to hang up after the greeting repeats 3 times. I hit save, but when I call that subscriber, it doesn't replay the message, and it's trying to have me leave a message. I've even checked the box that says "Do not play the 'record your message at the tone' prompt". The funny thing is, half of the subscribers I've setup work fine, and this isn't a problem, but the other half all want to leave a message instead of repeating the greeting. Can anyone tell me what I've overlooking? Thanks in advance!
Correct Answer by ranpierce about 8 years 6 months ago
I would first look at all the greetings,
standard, closed, and alternate and which ones are enabled.
if alternate is enabled then it take place of standard and closed.
this is a start.
Randy
Overall Rating: 5 (1 ratings)
Correct Answer
ranpierce Tue, 10/28/2008 - 11:38
  • Silver, 250 points or more
this is a start.
Randy
jonathanwalton Tue, 10/28/2008 - 11:47
You're right on the money. For some reason the person that was given the task of leaving the greetings on the second half of the menu tree always recorded on the alternate greeting. This resolved my issue - can't believe I did't think of that. Thanks!
ranpierce Tue, 10/28/2008 - 12:49
Just needed another pair of eyes on it.
Glad to help. =)
