10-28-2008 12:24 PM - edited 03-04-2019 12:06 AM
Hi all
I have an ADSL line connected to 2811 router and configured PPPoE on the router.this router is connected to ASA where all the inside network is PAT ed to outside interface of the ASA.My question is in ADSL router what IPs should I NAT in "ip nat inside source list" accesslist?Whether it is only the outside ip of ASA or All the inside network behind the firewall
Thanks in advance
Solved! Go to Solution.
10-28-2008 12:43 PM
Then you should NAT all your public IP's (or at least the ones being used).
10-28-2008 12:30 PM
Are you NATing at the firewall? If so, you should not need to NAT on the router, just let it route.
10-28-2008 12:39 PM
Thanks Collin for quick response
Yes. I am NATing at the firewall.But not to any Public IP.But to a private ip of subnet used only between ASA and ADSL router.From ASA i am pointing default route to ADSL router where PPPoE is configured.
10-28-2008 12:43 PM
