Changing standard Unity wav files..
Oct 28th, 2008
I have a customer running Unity 5 that needs to adjust the message prompt wave file. They need a few seconds on silence before the beep is played. Unfortunatly the advanced setting tool doesn't add the time before the beep in som instances.
Right now I'm stuck trying to find which wav file is the one I need to replace. I hear there is a document somewhere that lists these but I've been unable to find it. Does anyone have a link or know which file is the beep right before you can leave a message?
Thanks.
Justin
Bradford Magnani Tue, 10/28/2008 - 16:09
  • Cisco Employee,
Justin,
EDIT: My previous link was being cut off, but here's what I said in a previous post.
If you enable the Micro Trace "Phrase Server To Monitor" this should give you the output in the Port Status Monitor of the .wav file playing at that time.
Brad
