10-28-2008 01:17 PM
After a electric problem in our office both router cisco 12006 reboot. I monitorized both equipoment using MRTG and this OID are now no response. The SNMP and anccess list is well configurated. I can graph the traffic in each interface but for this varibles (temperature,CPU,memory) i can't. Here you see what OID i'm using.
Temperature: 1.3.6.1.4.1.9.9.13.1.3.1.3.2
CPU:1.3.6.1.4.1.9.2.1.58.0
RAM: 1.3.6.1.4.1.9.9.48.1.1.1.5.1 and 1.3.6.1.4.1.9.9.48.1.1.1.6.1
What happened in this case?
Thank you for your help
10-28-2008 01:21 PM
System image file is "disk0:c12kprp-k4p-mz.120-32.SY6.bin". this war working well until the electric fail. We change one of tha chassis and the problem continues
Thank you
10-29-2008 07:27 AM
Have you tried to snmpwalk the OIDs:
1.3.6.1.4.1.9.9.48.1.1.1.5 and 1.3.6.1.4.1.9.9.48.1.1.1.6
Note that I removed the last number from each OID.
10-29-2008 12:37 PM
For all OID i got the answer. If don't put any OID the server can make the read SNMP but not for this OID. Also the Nagios says "SNMP problem - No data received from host"
Here you have the SNMPWALK tha you are asking:
a) root@nagios# snmpwalk -c icroccs7521net -v2c 200.75.113.3 1.3.6.1.4.1.9.9.13.1.3.1.3
system.sysUpTime.6.1.4.1.9.9.13.1.3.1.3 = No Such Instance currently exists at this OID
b) root@nagios:# snmpwalk -c icroccs7521net -v2c 200.75.113.3 1.3.6.1.4.1.9.2.1.58
system.sysUpTime.6.1.4.1.9.2.1.58 = No Such Instance currently exists at this OID
c)root@nagios:/usr/local/nagios/libexec# snmpwalk -c icroccs7521net -v2c 200.75.113.3 1.3.6.1.4.1.9.9.48.1.1.1.6
system.sysUpTime.6.1.4.1.9.9.48.1.1.1.6 = No Such Instance currently exists at this OID
10-29-2008 08:27 PM
Do you mind posting the snmpwalk of .1.3.6.1.4.1.9 branch?
10-29-2008 09:08 PM
a) root@nagios:# snmpwalk -c icroccs7521net -v2c 200.75.113.3 .1.3.6.1.4.1.9
enterprises.9 = No Such Object available on this agent at this OID
Now with the point in first position
a)root@nagios:# snmpwalk -c icroccs7521net -v2c 200.75.113.3 .1.3.6.1.4.1.9.2.1.58.0
enterprises.9.2.1.58.0 = No Such Object available on this agent at this OID
b) root@nagios:/home/bqtn4g# snmpwalk -c icroccs7521net -v2c 200.75.113.3 .1.3.6.1.4.1.9.9.48.1.1.1.6
enterprises.9.9.48.1.1.1.6 = No Such Object available on this agent at this OID
what do you think now what's wrong with the router?
10-30-2008 08:58 AM
Check out bug CSCsq50837.
Workaround:
Add
snmp-server view v1default ciscoMgmt included
in the configuration of the device.
10-30-2008 11:22 AM
can you send a .pdf with the explination of that bug? please because i can access to bug toolkit before i put that line in the router configuration :(
Thank you.
10-30-2008 05:36 PM
10-30-2008 08:01 PM
Thank you very much..tomorrow i will apply the command in the router. I report you if i can solve the problems.
Best Regards
10-31-2008 12:41 PM
Yes. Now it's working prefectly. Thank you very much for your help.
Best Regard
Carlos Armas
10-29-2008 08:33 PM
Actually, I was wondering why your system translates the OID to system.sysUptime.6.1.4.1.9...
system.sysUpTime is generally translated to .1.3.6.1.2.1.1.3
Could you try the same snmpwalk with a preceeding '.'?
