10-28-2008 01:27 PM - edited 03-18-2019 09:53 PM
Hi, I used to do the transcoding on C2800 with image, adventerprisek9_ivs-mz.124-21(Mainline) and it was working. I don't use other CME or CCM, the sdspfarm registered to the internal CME v3.3.
After I upgrade the image to adventerprisek9-mz.124-20.T1, it doesn't transcode the call. The sdspfarm unit is registered to CME fine.
Can anyone tell me what's the difference in the new IOS?
Router#sh telephony-service
CONFIG (Version=7.0(0))
Version 7.0(0)
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip source-address 172.16.10.10 port 2000
max-ephones 10
max-dn 10
max-conferences 8 gain -6
dspfarm units 1
dspfarm transcode sessions 10
dspfarm 1 XCODE123456
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web: disabled.
edit TIME through web: disabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Oct 28 2008 15:04:13
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
max-ephones 10
max-dn 10
dspfarm units 1
max-redirect 5
time-format 12
keepalive 30
timeout busy 10
timeout ringing 180
max-size: 150
retain-timer: 15
Also, I noticed the minimal frame byte of G.711 is changed to 160 in the new IOS like below, could it be a issue? Thanks.
voice class codec 100
codec preference 1 g711ulaw bytes 160
codec preference 2 g711alaw bytes 160
codec preference 3 g729r8 bytes 20
codec preference 4 g729br8 bytes 20
codec preference 5 g723r63 bytes 24
11-03-2008 05:53 PM
You can't get CME to transcode codec when voice-class of multiple codec preferences is used in the call. CME does not do end-to-end codec negotiation between the two call legs to find out if it needs to transcode. It needs to be told to just do it. Hence, you need to force the two call legs to independently settle to the differing codec, by either using only one codec in the class or hard coding the codec in the dial-peers. When the bridging of the two legs fail, CME will insert the transcoder.
11-05-2008 08:01 AM
Thanks for your reply.
I upgraded the CME to 7.0 later on and tired SIP/G.711 and SIP/G.729 to H.323/G.711, both are working. It seems the router has a implied dial-peer for any incoming calls.
However, when I tried H.323/G.711/Faststart to H.323/G.729, it didn't work wheather I enable call start interwork in H323 configuration (The H.323 destination needs faststart and tunnelling enable).
