10-28-2008 01:48 PM - edited 03-04-2019 12:06 AM
In Cisco Student Guide, it says that the Router BGP command does not activate BGP. However, on my lab router, it shows this:
(config)#router bgp 5500
(config-router)#exit
(config)#router bgp 5600
BGP is already running; AS is 5500
Any idea?
Solved! Go to Solution.
10-28-2008 02:29 PM
Hello Wassim,
you cannot have a router on both BGP AS 5500 and BGP AS 5600 I usually use this to show this.
A BGP AS is owned by a company that got it from RIPE or ARIN (Regional Internet Registries)
And I agree with you once you enter router bgp 5500 the process is created.
Very good point
Hope to help
Giuseppe
10-28-2008 02:10 PM
It's running; the guide is incorrect.
--John
10-28-2008 02:29 PM
Hello Wassim,
Very good point
Hope to help
Giuseppe
10-30-2008 09:53 PM
we can not configure 2 AS in one router
