show isdn status output
Oct 28th, 2008
What does this message mean when I do a show isdn status on the BRI interface of my ISDN BRI link? Please see below.
xxxx_1841#sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 2 NOT Activated
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x00000000
Total Allocated ISDN CCBs = 0
Giuseppe Larosa Tue, 10/28/2008 - 14:33
  • Hall of Fame,
    Founding Member
Hello Bernardette,
this means your BRI is not working at all because ISDN layer 1 is deactivated
check the switch type you should use: be aware that basic-net3 is good for Europe only.
Ask the ISDN provider what switch type to use
if basic-net3 is fine check the cable
Hope to help
Giuseppe
