Callmanager with MGCP Gateway
Oct 28th, 2008
I am having problem with the configuration of a PRI circuit on a MGCP 3825 VGW. When testing, the carrier is up but the D-Ch is down (hard per the Carrier). I have changed each Protocol type, but haven't been successful. Is there a setting in the VGW that has to be set on the port?
NOTE: We have order new circuits from a different carrier. The existing PRI is good with (B8ZS, ESF NI2) New carrier requires 5e Custom. That's the only change.
Jaime Valencia Tue, 10/28/2008 - 14:27
  • Cisco Employee,
  • Hall of Fame,
    2011
can you post the relevant config and a sh isdn status??
java
if this helps, please rate
