ACS Network Access Restriction not working. Should deny, but allow.
Answered Question
Oct 28th, 2008
  • Bronze, 100 points or more
I'm having problem with the Network Access restrictons on the group configruation of ACS.
I configured the NAR field of a group and set it to deny access besed on AAA client, a Wireless Lan controller.
But users in this group is still able to log in wireless controller.
The Logs of ACS shows the fields are right. the right user, in the right group in the right AAA client, but does not deny.
Correct Answer by Jagdeep Gambhir about 8 years 8 months ago
Also set up DNIS based restriction.This is how it should be configured,
- Steps for configuring NAR's:
1) Go to User setup ----> Select the username you want to restrict.
2) Go to Network Access Restrictions (NAR) option.
3) Under Per User Defined Network Access Restrictions.
4) Check the "Define CLI/DNIS-based access restrictions box.
5) Select "Deny Calling/Point of access location"
6) In AAA client drop down box --- select the name of the the device to which user should not connect.
7) In Port ---- Use *
8) In CLI ---- Use *
9) In DNIS ---- Use *
10) Click on submit
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
Correct Answer
Jagdeep Gambhir Wed, 10/29/2008 - 08:01
  • Red, 2250 points or more
10) Click on submit
~JG
