10-28-2008 04:11 PM - edited 07-03-2021 04:42 PM
I can't get my 871w to enable WPA2 for it. I found a reference to "wpa version 2" as CLI which my rather new IOS doesn't seem to understand.
So how to enable WPA2 via CLI commands? And by the way do you have a link to the wireless CLI reference?
Ciao, Bernd
10-30-2008 06:26 AM
I seem to remember that the 871 series does not support AES. I last touched one of these well over 6 months ago, and I remember being surprised that it didn't support it. Without AES, there's no way to configure WPA2.
To find out, enter the following:
int Dot11Radio0
encryption mode ciphers ?
If it lists aes, you're good. If not, you'll need to use WPA and TKIP, which is still a good solution.
10-30-2008 11:04 AM
Hi Jeff,
thanks for message and the help - I appreciate that!
Yes my router shows the option:
CiscoKunr(config)#int Dot11Radio 0
CiscoKunr(config-if)#encryption mode ciphers ?
aes-ccm WPA AES CCMP
tkip WPA Temporal Key encryption
wep128 128 bit key
wep40 40 bit key
And I set it to aes-ccm, but my client (Macbook) says it's still WPA and not WPA2 like my D-Link wireless. Is the message of the Mac OSX wrong or do I miss something else in the setting for WPA2?
Ciao, Bernd
10-30-2008 02:54 PM
Hi Jeff,
it's me again. I checked the WLAN again with a Windwos cleitn and yes - now with the setting aes-ccm its shown as WPA2!
Thanks again!
10-31-2008 05:50 AM
Great, glad to hear it! Now I'm second-guessing myself, I think it was an 1841 wireless module that didn't support AES.
