class-map type inspect statement with out match statement
Oct 28th, 2008
In a ZBF (IOS 12.4(20)T1, what happens if the following class-map is used in a policy which is tied to a zone pair and an interface, but the class-map does not have a "match" statement under it? Is the default to drop all since there is no match? Or since there is a "match-any" statement, does it pass all traffic? This was set up automatically by SDM 2.5 and I'm trying to figure out what will happen here?
class-map type inspect match-any no-match
class-map type inspect match-all willwork
match class-map no-match
match access-group 110
policy-map type inspect whathappens
class type inspect willwork
inspect
class class-default
drop
zone security in
zone security out
zone-pair security out-self source out destination self
service-policy type inspect whathappens
interface GigabitEthernet 0/0
description Untrusted
zone-member security out
Scott
Overall Rating: 4 (1 ratings)
Marwan ALshawi Tue, 10/28/2008 - 19:45
as long as the class dose not have match
no action will be taken until the match occuer
so nothing will happen
to make sure
do show policy-map whathappens interface GigabitEthernet 0/0
and see the matched traffic
it show 0
good luck
if helpful Rate
sdniel Wed, 10/29/2008 - 07:36
When you say "nothing will happen", are you saying it will "pass" all traffic or "drop" all traffic?
Marwan ALshawi Wed, 10/29/2008 - 14:46
actually it will not pass or drop
the logic is
the calss map do matching then if there any match happend then the policy map that associated with this class will look what action configured to be taken
in ur case nothing will be match so the next stage which is the action stage will not be considered
hope this helps
sdniel Thu, 10/30/2008 - 07:07
So in this case, since class-map no-match is nested within class-map willwork, which has a match-all statement match class-map no-match "anded" with access list 110, does the policy whathappens inspect packets for only access-group 110? Wou8ld the result be the same if class-map no-match did not exist at all? You state that is does not pass or drop packets, so what does it do with them?
