%SYS-3-CPUHOG because of Inspect process
Oct 28th, 2008
We are having 7206 VXR with NPE G2 getting %SYS-3-CPUHOG: Task is running for (48004)msecs, more than (2000)msecs (1464/11),process = Inspect process.
And links are flapping beacuse of this
Couldnt find much info on CPUHOG because of Inspect process
Pls refer to the attached logs and suggest
Amit Singh Tue, 10/28/2008 - 22:13
  • Cisco Employee,
Madan,
I see some tracebacks also generated by the router. I am unable to decode the tracebacks and didnt find much info on the CPUhog error that you are getting. I would suggest the following :
- Try upgrading the router software to a latest one and sometimes it can take care of any cosmetic problem with the software.
- Open a TAC and report the problem to the TAC.
-amit singh
madan.kumar Tue, 10/28/2008 - 22:30
We had already upgraded the sw frm 124-15.T5 to 124-22.T.I coudnt find any Bug mathes with 124-22.T.
The blow are the mathes i found related to CPU HOG
CSCsu01812
CSCsm72482
CSCso62511
We are using IP INSPECT for SIP calls the below is the related config
interface Multilink7
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip accounting precedence input
ip load-sharing per-packet
ip nat outside
ip inspect voip in
ip virtual-reassembly
load-interval 30
no keepalive
ppp multilink
ppp multilink group 7
ppp multilink fragment disable
interface Serial3/0
ip nat outside
ip inspect voip in
dsu bandwidth 44210
framing c-bit
cablelength 25
serial restart-delay 0
Pls let me know is anything we can chk before considering TAC
Madan
nehakulsum Thu, 10/30/2008 - 09:40
Hello Madan,
%SYS-3-CPUHOG: Task is running for ([dec])msecs, more than ([dec])msecs ([dec]/[dec]),process = [chars].[chars]
The indicated process ran too long without relinquishing the processor. Each process should run for a small amount of time and then relinquish the CPU so other processes can run. This problem can be caused by many things like traffic or system load, hardware or operational configuration, a configuration change, initialization (of many interfaces, cards or ports for example), a high momentary error rate, a sustained abnormal condition or many other conditions.
And when i decode i got for following information:-
%SYS-3-CPUHOG: Task ran for [dec] msec ([dec]/[dec]), process = [chars], PC
= [hex].
Explanation: Every process that runs must relinquish the processor after a certain
period so that other processes can run. 'CPUHOG' is an informational message that
occurs when a certain process holds the CPU for 2000 msec or longer. This problem
can occur due to one or more of these conditions:
Heavy Traffic
System load
Faulty hardware
Improper operational configuration
Configuration change
Initialization of many interfaces
High momentary error rate
Sustained abnormal condition
Software bug in the IOS during normal operation.
Recommended Action: If communication is fine, and no other messages are displayed
before this message, you can ignore the CPUHOG message. If another error message
appears along with this message, decode the other error message using the Error
Message Decoder tool. If the CPU usage is high because of IP input process, then
the router is process-switching a lot of IP traffic. Enable CEF to lower the CPU
usage by this process. Review the Bug Toolkit for potential issues related to
this issue.
STACK DECODE NOTIFICATIONS (if any)
Note: Understanding the 'Fixed In Version' field - Sometimes the fixed-in version
specified may not be available for download from the IOS Upgrade Planner. This
is because, bug fixes are incorporated into software versions which have not been
regression tested. These builds are called interim images and will have a "."
in the build number found between the parenthesis, for example 12.3(8.1). The bug
fix will be in the next available image, and all later images. So if a bug is fixed
in 12.3(8.1), the bug fix is present in 12.3(9), 12.3(10), and so on.
REFERENCE: For more information on how IOS images are named, see Cisco IOS Reference
Guide.
The failure was caused by a software defect.
Also you see there is huge peak on the cpu status. anyways As suggested by amit you could probably think of upgrading IOS on the device.
If you still required you can contact cisco tac.
Neha
madan.kumar Thu, 10/30/2008 - 20:44
Hi Neha
Thanks for that, I was just wondering why exactly the INSPECT process causes high cpu?
JUST ATTACHING THE SH IP INSPECT ALL output
sh ip inspect all
Session audit trail is disabled
Session alert is enabled
one-minute (sampling period) thresholds are [unlimited : unlimited] connections
max-incomplete sessions thresholds are [unlimited : unlimited]
max-incomplete tcp connections per host is unlimited. Block-time 0 minute.
tcp synwait-time is 30 sec -- tcp finwait-time is 5 sec
tcp idle-time is 3600 sec -- udp idle-time is 30 sec
tcp reassembly queue length 16; timeout 5 sec; memory-limit 1024 kilo bytes
dns-timeout is 5 sec
Inspection Rule Configuration
Inspection name voip
sip alert is on audit-trail is off timeout 30
udp alert is on audit-trail is off timeout 30
Interface Configuration
Interface Serial3/0
Inbound inspection rule is voip
Outgoing inspection rule is not set
Inbound access list is not set
Outgoing access list is not set
Interface Multilink7
--More-- Inbound inspection rule is voip
Established Sessions
Session 7351A74 (202.69.195.115:9298)=>(192.168.35.67:56576) udp SIS_OPEN
Session AF39E84 (202.69.195.115:13580)=>(192.168.35.67:32440) udp SIS_OPEN
Session 7347BEC (202.69.195.115:9299)=>(192.168.35.67:56577) udp SIS_OPEN
Session 7354164 (202.69.195.115:5743)=>(192.168.35.67:46049) udp SIS_OPEN
Session 734A5A4 (202.69.195.115:13581)=>(192.168.35.67:32441) udp SIS_OPEN
Session 734F64C (192.168.35.67:52240)=>(202.69.195.115:9682) sip-RTP-data SIS_OPEN
Session 734A2DC (202.69.195.115:14070)=>(192.168.35.67:49404) udp SIS_OPEN
Session 734BEAC (202.69.195.47:5060)=>(192.168.20.5:5060) sip SIS_OPEN
Session 7345D54 (202.69.195.115:14503)=>(192.168.35.67:25973) udp SIS_OPEN
Session 734EDF4 (202.69.195.115:9683)=>(192.168.35.67:52241) sip-RTCP-data SIS_OPEN
Session 734A86C (202.69.195.115:11947)=>(192.168.35.67:58373) udp SIS_OPEN
Session 735390C (202.69.195.115:5742)=>(192.168.35.67:46048) udp SIS_OPEN
Session 7353BD4 (202.69.195.115:5701)=>(192.168.35.67:22537) sip-RTCP-data SIS_OPEN
--More-- Session 734C9CC (58.27.96.229:5060)=>(192.168.10.7:5060) sip SIS_OPEN
Session 734601C (192.168.35.67:25856)=>(202.69.195.115:14592) sip-RTP-data SIS_OPEN
Session 7352B24 (202.69.195.115:5700)=>(192.168.35.67:22536) udp SIS_OPEN
Session 734FEA4 (202.69.195.115:14502)=>(192.168.35.67:25972) udp SIS_OPEN
Session 734D4EC (202.69.195.115:11946)=>(192.168.35.67:58372) udp SIS_OPEN
Session 734BBE4 (192.168.35.67:55345)=>(202.69.195.115:5323) sip-RTCP-data SIS_OPEN
Session 7347EB4 (202.69.195.115:14593)=>(192.168.35.67:25857) sip-RTCP-data SIS_OPEN
Session 734AB34 (202.69.195.115:14071)=>(192.168.35.67:49405) udp SIS_OPEN
Session 73514E4 (192.168.35.67:55344)=>(202.69.195.115:5322) sip-RTP-data SIS_OPEN
sip-RTCP-data SIS_OPENING
Session 734B0C4 (192.168.10.7:39344)=>(202.69.195.47:5060) sip SIS_OPENING
Pre-generated Sessions
Pre-gen session 734DD44 192.168.10.7[1024:65535]=>202.69.195.47[5060:5060] sip
Pre-gen session 734F914 202.69.195.47[1024:65535]=>192.168.10.7[5060:5060] sip
Pre-gen session 7346B3C 202.69.195.47[1024:65535]=>121.243.16.135[5060:5060] sip
--More-- Pre-gen session 7352004 192.168.10.7[1024:65535]=>58.27.96.229[5060:5060] sip
Pre-gen session 734922C 58.27.96.229[ Pre-gen session 734CC94 58.27.96.235[1024:65535]=>
Planning to go for 12.4 15 T7 since the Bug tools are not yet updaed for the present 12.4 (22)
Madan
