Catalyst c3750G Integrated WLC
Oct 29th, 2008
Hi All,
I'm setting up a catalyst 3750G with integrated WLC switch for a client. The swithing portion look good, but i'm facing problem with bringing up the WLC. Below is the information.
WLC Software:
ap-manager LAG 1 Static
management LAG 1 Static
service-port N/A N/A Static
virtual N/A N/A Static
wlan_773 LAG 773 Dynamic
The problem that i'm facing now is i can't connect to the management interface from the network even i've configure an IP for that. As from the Cisco Doc, the LAG is the only option for this integrate WLC, i cannot disable it. The 3750G is the same management IP as the WLC management interface, which's
the management IP for WLC and 3750G are within the same VLAN and subnet, and both the devices trunking are connected, how come they can't reach each other?
orochi_yagami Wed, 10/29/2008 - 02:22
Hi all,
I managed to resolve this issues by referred to another post from this forum session also.
