Unity7 Domino8 DUC125
Answered Question
Oct 29th, 2008
I am installing Unity7.0.2 unified with Domino8, Notes8 and DUC125FRA for Win
I've installed csServer on Domino server: ok
When I try to install csAdmin like I read in Cisco Unity Doc, it telles me Notes client is not installed. IBM does not recommend to do that .
What can I do ?
When is csAdmin used ? only once like AD shema Modif ?
Is it possible to install it on a client PC with Notes with admin rights ?
Correct Answer by Tray Stoutmeyer about 8 years 2 months ago
Any time! Please rate if this helped you.
Tray
Overall Rating: 5 (1 ratings)
Tray Stoutmeyer Wed, 10/29/2008 - 07:54
Guy,
You are right, you do not install csadmin on the Unity server and it won't be allowed per doc here.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/installation/guide/cudnf/IG_018.html
You need to run this from a pc that has Notes installed and the user account myst have at least Desinger access to the Domino directory.
You must also make sure the Domino Administration server selected during the csadmin install is running.
Tray
