Unity7 Voice recognition Server
Oct 29th, 2008
Is it possible to install VoiceRecognitionServer on the same server as Unity7 (7825 I3) ?
Overall Rating: 5 (3 ratings)
rob.huffman Wed, 10/29/2008 - 05:36
Hi Guy,
A dedicated ***server is a requirement to use these "cool" features;
Managing Voice-Recognition
Voice-recognition features allow subscribers to interact with Cisco Unity by speaking rather than by using the phone keypad. The features are licensed by number of concurrent sessions, and ***require installation and configuration of voice-recognition software on a separate and dedicated server. Voice recognition is not available to outside callers.
Hope this helps!
rob.huffman Wed, 10/29/2008 - 06:59
Hey Brad,
Very nice indeed! Can you expand upon this one feature in particular;
**Configures on Cisco phones as a dialtone replacement or as a speed-dial setting.
As always, Thanks!
PS: +5 Points for this nice addition :)
Bradford Magnani Wed, 10/29/2008 - 07:50
Basically what that's saying is that you can configure a phone to PLAR to Speech Connect to eliminate dial tone. And the speed-dial is pretty self explanatory, setup for dialing Speech Connect directly from a phone.
Hope that answers your question.
rob.huffman Wed, 10/29/2008 - 08:50
Hi Brad,
Makes perfect sense! I wasn't thinking along those lines but this has some really great applications.
Thanks very much for this!
Chris Deren Wed, 10/29/2008 - 09:16
I dont consider the speech recognition engine that requires you to say "3" instead of "delete message" as "cool". If you have to know the DTMF option why would you say it? That was the how Unity speech connect behaved last time I checked. It has some way to go in my opinion to be worth implementing, especially with dedicated server.
rob.huffman Wed, 10/29/2008 - 09:30
Hey Chris,
I have to agree that some of this has limited application value for many (but not all) users. We just worked with the "Speech Recognition" portion of UC 7.0 over the last number of months but not like this Speech Connect. I did think of some applications for accessability that would be worthwhile for sure. I just like the added flexability that these options provide.
I can see some good value for users who don't like searching through the IP Phone directory, so maybe set them up with a Speed Dial key to the "Speech Connect" Voice directory. I could search for "Chris Deren" just by saying your name:)
The PLAR idea has some merit for phones that are in Lobby's or secure areas that you want to be able to contact users without knowing their DN's etc.
+5 points for weighing in on this my friend. As always, much appreciated.
