ASA5510 and Globesurfer Site-to-Site VPN
Oct 29th, 2008
I am trying to configure a Site to Site VPN between an ASA5510 and a Globesurfer_II via 3G. I have am almost sure that the problem lies with the GlobeSurfer. But I am hoping that someone else may have seem a similiar problem. I am not even getting pass the first phase of isakmp. I m running ver 7.2 of the ASA software.
I have also test the same globe surfer device using a known working VPN client and it also fails. Take a the Globe Surfer and the Cisco VPN client works using teh same 3g sim.
Any ideas on how to trouble shoot this issue or even fix it.
singhsaju Wed, 10/29/2008 - 08:05
Try to match Isakmp/Ipsec parameters on both sides.
First use simple /basic parameters to just bring up tunnel .Make sure you are able to ping the VPN peers .Check if there is no NAT/PAT device in between.
Phase 1
authentication: pre-share
encryption: 3des
Hash: md5
DH group : group 2
Lifetime for phse 1 SA : 86400 seconds
Match the isakmp key both sides.
Phase 2:
Transform set: ESP-3DES
Crypto ACL: mirror traffic
Life time for Phase 2 SA : 3600 seconds
Match above parameters for phase1 and phase 2 on both ends vpn devices.
Do not use optional parameters initially like PFS etc. Just try to bring up tunnel with only required parameters.
Saju
