mikram Wed, 10/29/2008 - 04:58
Just normal windows startup and shutdown procedure, only you need to make sure that Agents are not logged in or after hours of normal operations. If you are in HA mode, make sure failover works, you could check in control center if the service is Master or not. You could also force it to be active master.
cheers
Ikram
