QoS WAN ----DMVPN phase 3 ---MPLS cloud----
Oct 29th, 2008
I would like to configure QoS in our C "customer" router. We are using DMVPN phase 3. The ISP cloud is MPLS "ISP guys are willing to put some QoS on their CE router if we need too".
We notice that any time some users are doing big file transfer or copy all users that are using VDI are suffering.
What we want is to give high priority to VDI "Virtual Desktop Infrastructure, it like Citrix, using RDP protocol" and also to Exchange Mail with 60% of the total bandwidth.
Applications like FTP, Netbios copy will have a lower priority.
My questions are:
1) How can I achieve that?
2) Can we do that on the CE Router eventhough the packets leaves our C router encrypted. If yes, how to do it
Our C router --HUB----
interface Tunnel0
bandwidth 5000
ip address 10.100.106.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication DMVPN_NW
ip nhrp map multicast dynamic
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp redirect
ip tcp adjust-mss 1360
ip ospf message-digest-key 1 md5 <removed>
ip ospf network broadcast
ip ospf priority 10
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile SDM_Profile2
interface GigabitEthernet0/0
description outside$ETH-WAN$
ip address 172.24.2.5 255.255.255.248
duplex full
speed 100
media-type rj45
standby 1 ip 172.24.2.10
standby 1 timers 1 10
standby 1 priority 150
standby 1 preempt
standby 1 name hsrp
standby 1 track GigabitEthernet0/1 60
interface GigabitEthernet0/1
description inside$ETH-LAN$
ip address 14.20.142.5 255.255.255.0
ip ospf priority 0
duplex full
speed 100
media-type rj45
Our C router --Spoke----
interface Tunnel0
bandwidth 5000
ip address 10.100.106.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.100.106.1 172.24.2.5
ip nhrp map 10.100.106.4 172.24.2.4
ip nhrp map multicast 172.24.2.5
ip nhrp map multicast 172.24.2.4
ip nhrp nhs 10.100.106.1
ip nhrp nhs 10.100.106.4
ip nhrp shortcut
ip ospf priority 0
tunnel key 100000
tunnel protection ipsec profile SDM_Profile1
ip address 172.24.2.34 255.255.255.248
duplex full
speed 100
ip address 13.9.6.1 255.255.0.0
duplex auto
speed auto
Joseph W. Doherty Wed, 10/29/2008 - 06:18
Unable to discuss specifics for DMVPN phase 3, but in general CBWFQ applied at your congestion points (ofen WAN ingress/egress) is what you'll need.
Since your "C" routers doesn't have an interface on the actual WAN your two options are to shape (with a subordinate policy) to the WAN egress speed, or have the CE router process encrypted marked packets as desired. (Usually Cisco routers will copy the original packet's ToS to the encrypted packet's ToS, you just need to insure the ToS was correct before encryption.)
If your DMVPN cloud actually has multipoint communication, egress can congest from multiple sending locations. Here too you'll likely need a CBWFQ policy using ToS markings on the PE's egress. (Often MPLS vendors support some QoS models that you'll need to map your traffic into.)
