Device In DFM Still In Learning State
Answered Question
Oct 29th, 2008
All,
I added a device to DFM for the first time yesterday. When I added it the device was in a learning state. When I came in this morning to check the status it is still in the learning state. Does anyone know if this is normal?
Correct Answer by lotmueller about 8 years 9 months ago
are you running the system on a windows-server.
There are known-problems with .Net2.0 SP 1 Software.
CSCsm04957 Devices stuck at 10%
Conditions:
This will occur after the Microsoft .NET 2.0 SP1 package is installed.
Workaround:
Uninstall the .NET 2.0 SP1 package, then restart dmgtd.
Also, please check your DNS-Resolution, DFM has several problems with Forward/Reverse-DNS-Resolution errors.
Hope this helps
Overall Rating: 5 (1 ratings)
Correct Answer
lotmueller Wed, 10/29/2008 - 06:06
Conditions:
Workaround:
Hope this helps
mrashby Wed, 10/29/2008 - 06:39
Yes I am running it on a Windows box that has Microsoft .NET 2.0 SP1 installed. I will uninstall the patch and see what I get.
mrashby Wed, 10/29/2008 - 10:04
I uninstalled the MS Patch and restarted the services for CW and that did the trick. Thanks.
Mario
Joe Clarke Wed, 10/29/2008 - 10:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The better solution is to upgrade to LMS 3.0.1 then DFM 3.0.4 where this bug (and another learning bug) is fixed.
