No web interface CUE
Dimitris Mingos
I am unable to use the cue web interface.
My config is:
interface Loopback0
description $Loopback$
ip address 10.1.10.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
interface Null0
no ip unreachables
interface FastEthernet0/0
no ip address
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet0/0.1
description ** Data VLAN **
encapsulation dot1Q 1 native
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0/0.100
description ** Voice VLAN **
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
service-policy output output-L3-to-L2
interface Service-Engine0/0
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
ip forward-protocol nd
ip route 10.1.10.1 255.255.255.255 Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:gui
ip nat inside source list 1 interface FastEthernet0/0 overload
What is wrong>
Thank you
Markus Schneider
Can you ping the CUE? I'm not sure if you can't get to the module at all or if there's just something where you can't log into the GUI, etc. Is the module up (serv serv 0/0 status)? I would also try enabling ip proxy-arp on the loop0 interface. If that were a fastethernet interface, you'd need it for sure, because it you need it to respond on behalf of the CUE (since it's using ip unnumbered).
5 Replies 5
Markus Schneider
Yes, I can ping the module from CME and I can ping CME from CUE.
I am using 600 as voice mail, and when I am dialing it it responds.
And ... I am lost!!
I can also loggin to service-engine.
Any other suggestions?
Thank you.
The problem was solved by adding to the local PC:
route add 10.1.10.0 mask 255.255.255.252 10.10.10.1
Thank you anyway for your resonse!
But can you ping CUE from your PC that you're trying to access via the browser? If you can, can you successfully log into the CME GUI?
Yes after adding the "route add" line in my PC I am able to use the web interface.
