show ip traffic
Answered Question
what are the following fields:
bad hop count
not a gateway
this is my output, is there anything I should worry about?
3560G>sh ip traffic
IP statistics:
Rcvd: 2949456362 total, 2789289817 local destination
0 format errors, 50 checksum errors, 138095200 bad hop count
0 unknown protocol, 15373754 not a gateway
0 security failures, 0 bad options, 37440117 with options
Opts: 24 end, 0 nop, 0 basic security, 24 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 37440093 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 couldn't fragment
Bcast: 2151546650 received, 7213995 sent
Mcast: 25634738 received, 28523640 sent
Sent: 578904665 generated, 350387545 forwarded
Drop: 8735471 encapsulation failed, 5 unresolved, 0 no adjacency
316 no route, 0 unicast RPF, 0 forced drop
0 options denied, 0 source IP address zero
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 218975 unreachable
6494487 echo, 307 echo reply, 4 mask requests, 0 mask replies, 0 quench
0 parameter, 2 timestamp, 3 info request, 1 other
0 irdp solicitations, 0 irdp advertisements
Sent: 1854 redirects, 609413 unreachable, 444 echo, 6494461 echo reply
0 mask requests, 0 mask replies, 0 quench, 2 timestamp
0 info reply, 1041 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 2706662 total, 0 checksum errors, 1135 no port
Sent: 2707595 total
UDP statistics:
Rcvd: 2779869311 total, 0 checksum errors, 2143178403 no port
Sent: 569089856 total, 25259526 forwarded broadcasts
ARP statistics:
Rcvd: 26756489 requests, 113483 replies, 0 reverse, 0 other
Sent: 7674269 requests, 913150 replies (27324 proxy), 0 reverse
Drop due to input queue full: 0
Correct Answer by John Blakley about 8 years 5 months ago
Bad hop count is where the ttl expires and no gateway is routed traffic internally.
http://www.cisco.com/en/US/docs/ios/12_2/ipaddr/command/reference/1rfip2.html#wp1020634
--John
Overall Rating: 5 (1 ratings)
