dbenattou Wed, 10/29/2008 - 16:46
hello,
thanks for your reply.
i have converted it via voice manner.
the problem that i meet now is regarding the sent and reception of fax.
when i plug analog phone behind ATA, the calls passes, but fax not yet.
the confguration of the CCME as follow :
voice service voip
modem passthrough nse codec g711ulaw
dial-peer voice 3 voip
destination-pattern 1..
session target ipv4:X.X.X.X
fax rate disable
CODEC G711ulaw
Until now, the fax cannot been sent nor receive.
Is the configuration correct, or i need something else to pass the sent/reception
I'm waiting for your assistance .
Kind Regards
