Warning message
PIX 506 - any bandwidth controls or monitoring?
Oct 29th, 2008
Have a rogue user or 2 eating up our bandwidth. Is there a quick an easy way to monitor the top bandwidth users and/or restrict every port to 512k max (for example). Excuse the NOOB question, I've not worked on this model before and don't mind doing my homework on actually configuring it, just want to know if there's a quick and easy solution "built-in" Thanks!
andrew.prince@m... Wed, 10/29/2008 - 10:52
  • Green, 3000 points or more
AFAIK - the 506 cannot be upgraded to 7.x/8.x. In the 6.x code there is no QoS, or rate limiting config, so to answer your question - no.
You need to shape a device back.
HTH>
