Call Manager 5.0 License
Answered Question
Oct 29th, 2008
  • Bronze, 100 points or more
  • Participante em Destaque,
    Escolha da Audiência, Maio de 2015
I have 60 DLUs not used (for Cisco Devices), and now I need install a Third-Party device.
Need I buy a Third-Party license? Or can I use the my licenses?
Correct Answer by Jaime Valencia about 8 years 9 months ago
what device are you planning to install???
if it's going to be a sip phone you can use your licenses, if it's going to be h323 no license is required
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Wed, 10/29/2008 - 11:30
  • Cisco Employee,
  • Hall of Fame,
    2011
java
andre.ortega Wed, 10/29/2008 - 11:36
Thanks.
I will instal a sip device.
Have you a link with this information (about license)?
Best Regards.
Jaime Valencia Wed, 10/29/2008 - 11:38
  • Cisco Employee,
  • Hall of Fame,
    2011
simply go to the license calculator on your server and you will see both sip devices you can use, each one requires X amount of DLUs
java
andre.ortega Wed, 10/29/2008 - 11:43
Yes, I made this.
thanks again.
