WLAN
Oct 29th, 2008
Hi guys,
please could someone point me on the best approach as in hardware and configuration to setup WLAN to multiple branch offices in different locations to share resources via a head quarter
Thanks for your responds
jeff.kish Thu, 10/30/2008 - 06:20
  • Silver, 250 points or more
Is this autonomous or lightweight?
Segment, segment, segment is almost always the rule to follow. Unless you have a specific reason to do otherwise, place each office on its own VLAN, though using the same SSID is acceptable since that will allow for easy roaming. If possible, configure L3 links between the sites.
If you're using lightweight, I believe that you cannot use the same SSID with a different VLAN, assuming the APs are all on the same controller.
Hopefully this is what you were looking for. Let me know if it's not!
