10-29-2008 11:39 AM - edited 03-15-2019 02:14 PM
I have 1 phone with the wrong time. It is one hour back. I am in -8 time zone.
I rebooted the phone and nothing changed.
Any thoughts?
Randall
Solved! Go to Solution.
11-03-2008 06:51 AM
Check the firmware version of the phone in relation to the rest of your phones. If it is for some reason still on a firmware version prior to 8.2(2)SR1 - It most likely thought that Daylight Savings Time ended earlier than it actually did.
HTH,
Steve
10-29-2008 11:50 AM
Have you tried resseting the phone to factory default?
10-31-2008 12:55 PM
CM or CME ?
I had an issue with this on CME a while back, recreated the cnf files and rebooted the phones.
create cnf-files
11-03-2008 06:51 AM
HTH,
Steve
11-03-2008 08:21 AM
Hi All,
It was the firmware needed to be updated.
For some reason this phone did not upgrade the firmware in building 1(ccm's are in bldg3). Once I briught the phone to bldg 3 it upgraded fine.
The time is correct.
Now the question is why did this phone not upgrade the image?
Thanks for the help!
Randall
