How to add "remark" when modifing the named ACL ?
Oct 29th, 2008
There is a sequence number with named ACL. I can use the sequence number to add new ACL entry in the current ACL.
But I notice it does not allow me to put "remark". We use "remark" in ACL to section the ACl to make it more logically.
Ext Access List configuration commands:
<1-2147483647> Sequence Number
default Set a command to its defaults
deny Specify packets to reject
dynamic Specify a DYNAMIC list of PERMITs or DENYs
evaluate Evaluate an access list
exit Exit from access-list configuration mode
no Negate a command or set its defaults
permit Specify packets to forward
remark Access list entry comment
R1-3640-WAN(config-ext-nacl)#10 ?
See "remark" is not under "sequence". Why ?
Any workaround ?
Thank you in advance.
Overall Rating: 2 (1 ratings)
ajagadee Wed, 10/29/2008 - 12:26
  • Cisco Employee,
Hi Xuan,
Yes, you are correct, there is no option for "remark" using the sequence option while editing ACL Entries. This is a known limitation.
The only workaround that I am aware of, which I am sure you already know is to edit the access list via an external editor and remove and re-add the extended access list.
Arul
*Pls rate if it helps*
