Jon Marshall Wed, 10/29/2008 - 12:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
No it won't work. Some lines may be accepted but for example the interface configuration under 7.x is different to 6.3.
Jon
srue Wed, 10/29/2008 - 13:12
  • Blue, 1500 points or more
the interface and vpn configs will be pretty different, as will a few others.
if you upgrade a 6.3 pix with the config on it, to 7.x, it will do its best to 'upgrade' the config as well.
