Set port host in IOS
Oct 29th, 2008
Anyone know whte equavalent command in IOS for "set port host all" ?
Thanks.
Jon Marshall Wed, 10/29/2008 - 12:37
"switchport host" is the command you are looking for. It doesn't take an argument but in conjunction with the "interface range.." command it is close to what you want eg.
switch(config)# int range fa0/1 - 10
switch(config-if)# switchport host
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_46_se/command/reference/cli3.html#wp1948119
Note that not all switches necessarily support it.
Jon
glen.grant Wed, 10/29/2008 - 14:53
Almost all newer switches from 2950's up support the switchport host command , use it all the time .
