WDS Issue
Oct 29th, 2008
I have network of 7 AP's all of them 1240 series running with full IOS. I have configured one AP as WDS and the same AP is configured as local Radius server for WDS. All the AP's get registered with WDS and clients also get connected but just after making connection my clients keep leaving the BSS and roams or leaves/disassociates the AP. Few clients seems to be working fine but majority of them connects to the nearest AP tries to get IP from DHCP while client is going through this process it roams or leave BSS. This is really confusing for me as WDS is working fine and I can see all Ap's getting register to it but client connectivity is an issue.
Also I would like to know if I dont configure Local Radius Authentication for WDS, will roaming still work if one AP is WDS server and rest are client AP's
Omair
smahbub Tue, 11/04/2008 - 07:07
When you configure Wireless Domain Services on your network, access points on your wireless LAN use the WDS device (either an access point, an Integrated Services Router, or a switch configured as the WDS device) to provide fast, secure roaming for client devices and to participate in radio management.An access point configured as the WDS device supports up to 60 participating access points, an Integrated Services Router (ISR) configured as the WDS devices supports up to 100 participating access points.Try configuring WDS and LOCAL RADIUS Server on different APs.Configuring an external RADIUS server will also be a better option.
Take a look at this url:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38roamg.html#wp1035881
oqureshi Wed, 11/05/2008 - 01:22
Issue was solved after we upgraded the wireless network card drivers in IBM T60 laptops. For some reason if AP's are broadcasting multiple SSID's the old driver didnt seems to read the network properly. Its all ok now.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
