Unable to change DTIM period in WCS
A vendor is requesting that we change the DTIM setting under the Controller Properties / 802.11 b/g/n / Parameters / General section and the WCS 5.1.64.0 isn't allowing any change even though it appears I should be able to change this setting. This issue remains whether or not I have the WLAN enabled or disabled.
Any ideas? Is this a known issue?
We want to simply change it from 1 (default) to 10.
TIA
Rob Huffman Wed, 10/29/2008 - 14:14
Hi Tom,
Just in case you were not aware of the change for DTIM in 5.x
DTIM per WLAN-In 802.11a/n and 802.11b/g/n networks, lightweight access points broadcast a
beacon at regular intervals, which coincides with the Delivery Traffic Indication Map (DTIM). After
the access point broadcasts the beacon, it transmits any buffered broadcast and multicast frames
based on the value set for the DTIM period. This feature allows power-saving clients to wake up at
the appropriate time if they are expecting broadcast or multicast data.
In controller software release 5.0.148.0, you can configure the DTIM period for the 802.11a/n and
802.11b/g/n radio networks on specific WLANs. In previous software releases, the DTIM period
was configured per radio network only, not per WLAN. The benefit of this change is that now you
can configure a different DTIM period for each WLAN. For example, you might want to set different
DTIM values for voice and data WLANs.
Note The config {802.11a | 802.11b} dtim CLI command has been replaced by this new
command: config wlan dtim {802.11a | 802.11b} dtim wlan_id.
Note When you upgrade the controller software to release 5.0.148.0, the DTIM period that was
previously configured for a radio network is copied to all of the existing WLANs on the
controller.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn501480.pdf
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6521/product_bulletin_cisco_unified_wireless_network_software_release_5.0_ps7305_Products_Bulletin.html
Hope this helps!
Rob
Trending Topics - Security & Network
