Warning message
BGP neighbor shut
Oct 29th, 2008
when I issue a neighbor shut command, then a no neighbor shut command, I can not find the neighbor statement in the running configuration.
Is the shut command intended to delete the neighbor statement?
I have IOS 12.4
Jon Marshall Wed, 10/29/2008 - 14:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The neighbor shut command should only shut the BGP session down between the 2 peers. It should not remove it from your config.
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp3.html#wp1016748
Have you checked for any bugs for your specific version.
Jon
ccnpninja Wed, 10/29/2008 - 14:33
I found it.
I was entering a "neighbor x.x.x.x remote-as {AS} shut" instead of "neighbor x.x.x.x shut".
So apparently, I was shutting down all neighbors of that AS.
aguilas4191 Thu, 01/10/2013 - 12:04
Para apagar la sesión bgp
Ingresar al systema autonomo
GWAEROM-COA01A-00000(config)#router bgp 65
apagar la comunicación con el vecino
GWAEROM-COA01A-00000(config-router)#neighbor 2.1.2.1 shutdown
Para activar la sesión BGP
GWAEROM-COA01A-00000(config-router)#neighbor 2.1.2.1 activate
Saludos
