RME - Inventory Failing LMS 3.1
Oct 29th, 2008
I currently am running RME (LMS 3.1) on a windows box.
I currently have 44 devices failing during the inventory out of 188.
the IC_Server.log for doing 1 device shows this:
this is a 2621XM running (C2600-BIN-M), Version 12.3(1), RELEASE SOFTWARE (fc3)
Is this related to the IOS version running on this box?
Joe Clarke Wed, 10/29/2008 - 16:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is a known bug in the ENTITY-MIB in 12.3(1). You will need to upgrade to 12.3(2)or higher to get the fix. After that, subsequent inventory collections will work.
chris43290 Wed, 10/29/2008 - 16:44
Does this same bug affect WS-C4506 Software, Version NmpSW: 7.4(3) switches? 3.0.1 all my cat os switches worked, now they do not on version 3.1
Joe Clarke Wed, 10/29/2008 - 16:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. The bug ONLY affects IOS 12.3(1).
